Question about headers..
So.. I'm thinking of going with the street headers and their catted y-pipe... I'm gonna be moving back in towards Seattle before too long..
So there's 1-3/8" and there's 1-7/8"... same price. There's also 1-3/4" x 1-7/8" for $120 more. Not real sure which is the best choice... any thoughts there?
Also... do stainless need to be coated, or no?
HEAT. even with stainless they will still produce alot of heat. But if you are going to get a set of headers why not look into a set of edelbrock victors half the price even with coating them, and the performance is great they are a 1 3/4 to 1 7/8 steped and come with a high velocity merge collector which would help with low end tourqe. I just don't see spending the money on a set of stainless steal headers but thats just me.
Don;t get me wrong kooks are nice but the also carry a hefty price tag. with the money you save on the headers you could do a nice cam.
By the way these headers tuck up real nice, trust me. Just another idea for you.
Now granted, Zeke's Formy will probably never see the rain or DD duty.
How does the edelbrock coating hold up to the NW weather?
dont' know I never had them coated just high temp black paint, but then again remeber i was not so much into the bling factor. the jet hot on my old qtp's help up great execept where they scraped the ground.
The kooks do tuck up nice but usually bang the floorboard on acceleration. I would highly recommend doing poly motor mounts as well if you install Kooks.
If the car is not lowered more than an inch I would go with 1 3/4 Kooks, use the ORP and have the magnaflow bullet cats installed on it. If the car is stock hieght or an inch lower you can't go wrong with the edelbrock setup even with the cats I had 650 into the whole setup. VERY nice quality on both sets you can't go wrong on either.
One that I'm looking into a bit is that American Racing setup the vette guys really like them...
1 3/4 is more then enough unless you are planning on stroking the motor or ading a monster cam or getting truly radical.......I am sure there are better or at least equally as good headers out there, but if I was buying again, I would buy QTP or Kooks without a second thought!
I don't have a lot of ground clearance, my car sits reaaaaaallll looooooow... so I need something that gives me the maximum clearance, and a good clean fit... and I really can't picture them fitting much better than that picture. I've been doing searches on the board about headers for weeks, and they seem to be one of the more popular choices out there, everyone says the install is real simple, and seem to be pretty well made.
My Formula will have more ground clearance with LT's and being dropped 2" than my Trans Am has at stock height with a SLP Loudmouth.
I'd actually thought about doing Pacesetters for a while, but decided to bite the bullet and go stainless for appearance reasons.
So 1-3/4 seems to be the choice... and I'd assume I'd go with the "race" version if I want to do the EGR/AIR delete in the process... correct?
I went with the 1-7/8 because I've got the cam and nitrous,
from what I understand, I'm right on the edge of wether or not I will gain anything from the 1-7/8"
for the GTO at least,
they say above 550hp you should go with the 1-7/8
Yes you can get them in black but the "hi-tech" coating isn't that much more $$ and holds up quite well
