Cam swap help...
As for the technical discussion, all I can say is I've replaced about 10 cams in LS1s now. I can do it in ~8 hrs start to finish. And I STILL go see Ellis when I have a question. That tool is a MUST for the rear seal, but I've done the front seal without it & had no leaks. But if I had the choice I would use it....
I leave all the bolts loose until the pulley is seated then tighten up evenly... is this wrong?
