Cam swap help...
Also what size rod do I need to buy to hold the lifters up. I don't want to chance just letting them hang there......
And lastly will a regular 3 arm pulley puller work on the crank pulley or is it a special one? I have a small, medium, and large 3arm pullers.
I got this motor down to just the crank pulley, valve springs right now but it's too freakin muggy out there to continue...
Any help would be appreciated.
Thanks
Chad
Good luck.
This advice was brought to you sarcasm free by the one and only NVME.
http://www.thunderracing.com/catalog...&vid=3&pcid=17
They have the F-body tools for the valve springs too if no one will let you borrow theirs.
Hopefully a seasoned tech will come in pretty soon so they can tell you what you need.
Ellis, PM Sent
Right above the last 2 cylinders on the right side all I had to do was remove the plastic cowling....
Took my dremmel and cut away the metal that's above the heads and that gave me all the room I needed.
After I was done what I did was weld on a couple gate latches on the bottom so that in the future I have easy access again.
To get that crank pulley back on all I did was center it up on the crank and used a large socket and hammer and pounded it back on.
I got it all done tonight and just need to finish connecting my exhaust
