Northwest Members WA, OR, ID, MT, WY, SD, ND
squeeking belts?
Old Nov 8, 2007 | 10:09 PM
67camarors's Avatar
Default squeeking belts?
anybody else have this problem? i just replaced them like 3 months ago and they are already squeeking again
Old Nov 8, 2007 | 10:27 PM
crazylane's Avatar
Did you put any belt dressing on them? I know on my old beater that I had when I was a kid, I would throw sand on the belts and pullies as it was running. Lol. it got rid of the squeeking. But I would not suggest doing that to your car. Lol
Old Nov 8, 2007 | 11:10 PM
Evan Poinsett's Avatar
yeah, well actually i dont know if it is a belt or a bearing... either way it sucks
Old Nov 9, 2007 | 12:02 AM
19torch99's Avatar
My car is squeeking REALLY bad. It's loud at idle and only goes away at high rpm's(which I'm never in). Did the belt treatment so far w/ no luck.
Old Nov 9, 2007 | 12:11 AM
crazylane's Avatar
Try turning your AC on... If it goes away, then it is your compressor clutch. Thats what mine turned out to be..
And from past experince with belt treatment stuff. It usually made it worse on my cars.
Old Nov 9, 2007 | 12:29 AM
smoke20's Avatar
belt dressing is for v-belts not serp belts. dressing will only make the problem worse. you have two tensioners one for the main belt and one for the ac belt try changing them out along with new belts , i did that and no more belt squeak. also get good quality belts from dealer. cheaper belts seem to be a problem also.
Old Nov 9, 2007 | 02:34 AM
Ws6man2000's Avatar
From: Ft lewis,Ft sill and thats all i hope.Katy texas
ya the tensioners are cheap can get them from sdpc for like 40bucks or so.......fixed my squeaking
Old Nov 9, 2007 | 12:04 PM
67camarors's Avatar
ok thanks...i know its the belts because the last time i changed them the squeeking stopped completely. ill try turning the a/c on and what not. thanks for the help everyone
Old Nov 9, 2007 | 02:30 PM
Ackattack1's Avatar
mine is squeaking too...really annoying
Old Nov 9, 2007 | 03:54 PM
19torch99's Avatar
I tried the A/C and nothing happened with mine. Looks like I'm going to need new belts. Not good when you can hear the squeeking over the radio.
Old Nov 9, 2007 | 04:05 PM
crazylane's Avatar
Its probibly a pully then, How loud do you have your stereo? Like what was mentioned above. My be a pully tensioner
Old Nov 9, 2007 | 04:26 PM
67camarors's Avatar
if the radio is on i cant hear it. but if i turn the radio off i can hear it... its very annoying
