Hey guys and gals I've teamed up with Nasty
![](https://www.fquick.com/images/vehicles/full/492861193.jpg)
Here is the old version of the kit. You can see one red wire on the passenger side that loooks out of place because it is. It was a temp fix for a broken wire (not made by me). But you can see where they mount. The new kit incorporates bigger angle aluminum and larger threaded rod as well. I use acorn nut on the end caps. The new ones are also powder coated.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
mounting error ![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
The smaller angle aluminum also effected it.
Its tight under there. It not a 5 minute job, you need to have some skills to drill it. You might need to remove a valve cover, maybe not depending on your drill. I used a cordless porter cable full size to do it. I used self taping screw to make the pilot hole then the 1/4 " drill bit. My car is in my driveway but there isnt an engine in...lol so mounting it on my car isnt a real good example of it right now.
I guess I'm still on Blanco's ignore list. Could someone please ask him the question I asked about the long brackets. In the pictures I can't see them so if they aren't visible at all it wouldn't matter so please include that in the question. Thanks to anyone that would do that.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Blanco....
Is it possible to bend them with two 90 degree bends to make it match the coil mount brackets just to make them consistant?
The Manalishi, I hope I helped you out some... lol
#34
#35
Wow, I think this is the first time I have ever helped anyone on here...
How about some positive trader feed back.... lmao
I am truly blessed with some good luck today... ha ha...
