Northwest Members WA, OR, ID, MT, WY, SD, ND
motor work
Old Mar 26, 2008 | 05:08 PM
tmoney223's Avatar
Question motor work
Just wanted to know if anyone knows what there doing when it comes to motor work.. I want to put A MS3 cam in and new springs and rods....and what it would cost to do it....
Old Mar 26, 2008 | 05:10 PM
99LSS1's Avatar
where are you located? You can check out Ellis at Speed Secrets. 2fast4lv
crazylane's Avatar
Do it your self. Save yourself a grand.
edit: Or call Ellis. Sorry plinker, replied same time as you.
Old Mar 26, 2008 | 05:13 PM
99LSS1's Avatar
No problem Lane. He can do it himself, but just thought I would throw some business Ellis' way.
Old Mar 26, 2008 | 07:42 PM
firehawk618's Avatar
TWOFAST4LV aka Ellis if you want someone else to do it.
Old Mar 26, 2008 | 08:59 PM
NWDragRacer's Avatar
... or spend a grand on the tools to do it right.
x4 on Speed Secrets. aka 2fast4lv
Old Mar 26, 2008 | 09:18 PM
Mr.MartyStone's Avatar
Maybe 200 bucks for the tools...but a grand? You crazy!
Old Mar 26, 2008 | 09:21 PM
crazylane's Avatar
All it cost me was around 150, for the tools.
Old Mar 26, 2008 | 09:29 PM
Dmitriy's Avatar
Hey dude,
Might wanna look at http://ls1howto.com/
I did my own head/cam swap and I'm pretty much a noob. It was easy and saved me a ton of money.
Old Mar 26, 2008 | 10:02 PM
Rockin C Racing's Avatar
From reading other threads, he is located in the Portland area. TJWONG on this board has a shop in Vancouver, and is very knowledgable. If you choose to have someone do it, I highly recommend him, but as most have said, you can do it yourself and save some $$$. I rebuild all my own engines and several of us in the PDX area do our own work. Just ask if you need some help, I'm sure someone will help.
Old Mar 26, 2008 | 10:23 PM
99blancoSS's Avatar
I rent the tools out to do the job. I can also be available to help if you dont have the money to drop on a shop to do the work. It's not hard, you will how ever need to have someone tune it for you. We have a mail in option with Trifecta or you can take it to Turbo Tech or Ellis or Tom. Not sure of your location. I can do the work for you as well for a less expensive option but then you dont learn. If money for labor is not an issue then Ellis or Turbo Tech or Tom all have shops and are very qualified.
Old Mar 26, 2008 | 11:53 PM
KrautBurner's Avatar
Ellis 2Fast4Lv has done alot of the cam's around here (mine included)
great guy to deal with
Old Mar 27, 2008 | 01:21 AM
True that - just ask.
I believe that the criteria I stated was "to do it right". That includes verifing the cam timing (degreeing) and making sure what you bought is what you installed.
I wouldn't do it for less.....
Old Mar 27, 2008 | 05:55 AM
WAHUSKER's Avatar
No doubt about that....
Let's see here, 2 torque wrenches, sockets, wrenches, degree wheel, valve spring comressor, feeler gauges, LS1 pan alignment tools, floor jack, etc etc. yeah, easily a grand on tools to do it RIGHT.
But STILL crazy.
x5 for Ellis if you're up north, x2 for TJ if in Portland, Turbo Tech Inc in Tacoma if you're central.
Oh, and then there is tuning, which all 3 shops above can do, and do very well!
Old Mar 27, 2008 | 10:21 AM
tmoney223's Avatar
Thanks for the info guys....i live in kizer and dont have a shop or garage,so i would love to have someone to help me do it,i would love to work on it also just to get my hands dirty...I;ve been talking to Trevor at Texas Speed and i can get the springs,rods,and cam for 700.00+shipping..and thax again for the help!!
Old Mar 27, 2008 | 10:39 AM
crazylane's Avatar
Don't forget, oil pump, oil change, different crank bolt, and all the required seals and such.
Old Mar 27, 2008 | 11:05 AM
tmoney223's Avatar
This is what i need also right?
Basic Camshaft Bolt & Gasket Kit
Includes GM Timing Cover Gasket, GM Timing Cover Seal, GM Water Pump Gaskets & GM Harmonic Balancer Bolt. Everything you need for a basic camshaft swap!
More Detail
Item# 25-CAMKIT
$43.99
Old Mar 27, 2008 | 11:20 AM
99blancoSS's Avatar
Yes, there will be other little things that pop up as well. How many miles on your car and what year? You can bring it to my house and I'll help you do it if you want. You can slip me some money if you want its your choice.
Old Mar 27, 2008 | 11:39 AM
tmoney223's Avatar
it wont probably happen for a few months but that would be great if you could do that....just shoot me a price...but my car has 114k on it and its a 2000 so should i still do it or just buy a block and build it up????
Old Mar 27, 2008 | 11:41 AM
crazylane's Avatar
I have 110,xxx on my car. And just did a cam swap. You will be fine. Unless the car has been beatin on pretty bad.
