Northwest Members WA, OR, ID, MT, WY, SD, ND
Fuel pump going out???
Old Apr 2, 2008 | 03:57 PM
B-RAD2's Avatar
Default Fuel pump going out???
So this morning I went to start my car and it turned over then immediately died. I tryed it aga and the same thing.. So i looked at my fuel pressure gage with the key on and it was at zero. I pumped the gas pedal and it then started and ran fine for the drive to work...
I posted in the fuel section but got no replies...
Any ideas??
Thanks,
Brad
__________________
Old Apr 2, 2008 | 04:09 PM
Rokko's Avatar
Tech Addict
can you hear the fuel pump cycle up to pressure when you first turn the ignition to on but do not try to start it?
Old Apr 2, 2008 | 04:17 PM
NWDragRacer's Avatar
Any ideas??
Thanks,
Brad
__________________
Sounds like you have a PASS security issue. That's the same symptom my 'Burb had when a hack twisted wires on the PASS system when he installed the remote start.
Old Apr 2, 2008 | 07:36 PM
B-RAD2's Avatar
ya i can hear it Rick
Old Apr 2, 2008 | 08:48 PM
TwoFast4Lv's Avatar
F-Bodies don't have 'Pass' They have VATS and if it is set off the car will not even turn over
The key here was he saw 'Zero' Fuel Pressure.
Old Apr 2, 2008 | 09:52 PM
WAHUSKER's Avatar
Fuel pump or crank position sensor / wiring?
Old Apr 2, 2008 | 10:25 PM
Poik's Avatar
If you can hear the pump then check the FPR.
Old Apr 2, 2008 | 11:26 PM
Daredevil_TA's Avatar
usually if something is wrong with your VATS, your security light will come on--I would suggest looking at your ignition relay, mine would do the same thing sometimes, start an then just kinda die.
Old Apr 3, 2008 | 02:22 AM
TwoFast4Lv's Avatar
Originally Posted by Daredevil_TA
usually if something is wrong with your VATS, your security light will come on--.
Correct I got to learn alot about VATS one year
Old Apr 3, 2008 | 09:54 AM
B-RAD2's Avatar
I have had no problems what so ever with it since then....
Old Apr 3, 2008 | 09:48 PM
Ws6man2000's Avatar
From: Ft lewis,Ft sill and thats all i hope.Katy texas
if its vats the car will just not start... i had to replace my ignition on my ta when this happened
