Northwest Members WA, OR, ID, MT, WY, SD, ND
Oil pressure problem...
Old Apr 10, 2008 | 11:10 PM
LSxChevelle's Avatar
Default Oil pressure problem...
Well B-Rad2's oil pressure randomly dropped down to near red on the gauge so we installed a new LS6 oil pump (unported) today. Fired the car up and it went to 40 psi and higher when revved. Went for a quick drive and lost oil pressure. Wtf? What needs to be checked first? The pick up tube seemed to seat in the pump nicely and no other things seemed odd. Any ideas??
Old Apr 10, 2008 | 11:38 PM
Ackattack1's Avatar
maybe the gauge is bad?
Old Apr 11, 2008 | 01:54 AM
TwoFast4Lv's Avatar
I would have to say put a real gauge on it. I have seen it happen a few times where the gauge or sending unit freaked out.
If those check out there are a few areas deeper to look at and none of them easy while the engine is in the car
Old Apr 11, 2008 | 03:12 AM
smokinponcho73's Avatar
when rod bearings go dont you loose alot of oil pressure?
Old Apr 11, 2008 | 09:20 AM
WAHUSKER's Avatar
That's weird! Is it rattling like it really has no oil pressure Jason?
Old Apr 11, 2008 | 09:27 AM
B-RAD2's Avatar
It really doesn't sound bad. This started after i got it tuned. the oil prssure is fine at start up(when cold) but it drops once i get up to normal temp. On my way home last night driving down the freeway it was just under 20psi. When i stopped at a red light it dropped to just over the red.
Ellis- are you thinking about cam bearings??? I only have 40k on the motor
Old Apr 11, 2008 | 10:11 AM
firehawk618's Avatar
Sounds like the oil pressure sending unit.
Do like ellis said and put a regular mechanichal gauge in and take it for a drive.
At least eliminate that possibility. Seen many factory sending units act glitchy and do things similar to what you're describing.
smokin_powerstroke's Avatar
I hate to say it but when muff daddy had the 408 built that is now my car he had the same issues. Turned out that the original builder didn't check the line hone on the block and that caused the main bearings to go bad
Old Apr 11, 2008 | 10:36 AM
TwoFast4Lv's Avatar
Brad lets get the gauge on it and see where that takes us.
Old Apr 11, 2008 | 11:22 AM
KrautBurner's Avatar
we don't talk like that
Old Apr 11, 2008 | 02:21 PM
B-RAD2's Avatar
Ok so i need to pick up a gauge then... Just get one from the auto parts store???
Old Apr 11, 2008 | 02:30 PM
Im pulling my motor this weekend, thinking its a bearing
Old Apr 13, 2008 | 01:59 AM
muff daddy's Avatar
guaranteed its the mainbearings. mine acted the same way. i just hope your crank is salvagable.
Old Apr 13, 2008 | 11:34 AM
B-RAD2's Avatar
i'm still getting oil up top
Old Apr 14, 2008 | 01:08 AM
99blancoSS's Avatar
not another sick engine! sorry to hear
