Value of this Twin Turbo set-Up
So what would the used value be if someone was selling? Have a chance to pick it up pretty cheap, I think it's a good price. If it's not a good system for our cars then would it be a value for another?
Robert
RE: RE: TWIN TURBO KIT
Message:
Report as Spam/Abuse (2) GT3076S Turbo (450Hp capability per turbo)
(1) GT Spec XL FMIC intercooler (23x12x3 Inch 3 Inch Inlet & Outlet)
(2) Full Stainless Steel Chevy Small Block Turbo exhaust manifold (42mm
tubing, 2.9mm wall thickness)
(2) Super Sound BOV Kit (Includes all vacuum line, clamps, hoses, adapters)
(1) Set of turbo accessories
Turbo Details:
Oil cooled bearing system
Internal Wastegate at 14.5psi
T3 turbine inlet flange
2.75" Compressor Inlet for the max flow
All turbo are Balanced
Heavy duty K18 alloy turbine wheels
Super Shine Polished Surface for best appearance
2.75" V Band Turbine inlet or Switch able to 5 bolt turbine inlet
Compressor Housing: A/R.60
Turbine Housing: A/R.63
Max Speed( r/min): 130,000
2.75" V-band turbine outlet flange
Robert
Message:
Turbo Details:
Robert
Message:
Turbo Details:
Robert
Message:
Turbo Details:
I don't know which turbos those are but I have seen smaller turbos go for 500to 600 each used. The intercooler is thinner than I use. I use the el cheapo ebay intercoolers & they work great for me. they are 23x12x4" thick & run around 130.00 plus shipping.
I think you could use just one BOV & the manifolds are for a SBC? So you are basicallly getting 2 turbos with built in waste gates (which I have never used) that I believe requires a special t3 flange since you can't use the manifolds, a BOV & FMIC.
$1000??? pass on it.
I have no tech on the kit, but it's listed here:
http://www.ssautochrome.com/level.itml/icOid/1844
for $639
Jerome
for $639
Jerome
