Need someone with a tech 2 scan tool or similar
This is what I copied off of pcmforless.com, I need this done. anyone have the tool to do it? Hptuners, something? I live in St. Helens Oregon, and wanted to go play at woodburn tommorow, but I've got a minor glitch to take care of. I just got this pcm this afternoon.
"CASE relearn is a Crank Angle Sensor Error relearn, which realigns the position between the crankshaft position sensor and the camshaft position sensor. This relationship helps the vehicle determine advanced misfires. Anytime you install a new PCM into your vehicle that you intend to run long term, you need to have the CASE relearn done. So, this would apply to any of our core programs. The CASE Relearn can be done by anyone with a Tech 2 scan tool, advanced snap-on scanner, or also a Dashhawk or Aeroforce Scan Gauge depending on the vehicle. It is a 5 minute procedure. Cost will vary depending on where you go - you may want to call around first before deciding between the core program or loaner program. The CASE relearn will not keep the vehicle from running, however it should be done within at least two weeks of installing the new PCM."
