horsepower question
What gears do you have in your car now? are they the 3.42s or 2.73's? if they are the 3.42s then It might be wise to go with a 4.11.
And you will have a solid 11 second car that can still be farely dependable.
My car consisted of this.
PP TB, LS6 intake, LT's, TD's Dumped, Remove front sway bar, removed all the heat sheilding, removed the rear seats, removed the ac, had an ss3600 stall, a farelly good size cam. it was an XFI/XER lobe. and here is a video of one of my first shake down passes.
I have seen LT1 cars go well into the 11s with that and you have a 'Majic' motor
Heck we got a 7 cylinder car going 11.5s n/a with a stall H/C
