Track results
It's a forged 347, afr heads, home built turbo kit with a Tubonetics TC 78.
I have a T400 with 2.75 rear gears. The gears are for gas mileage, i still drive this to work etc. I have been driving it for a couple of years on this set up but didn't get to a track until last night. It did 6.1 in the 1/8 then fell flat on it's face in third gear. We don't know why, it felt like it was running pig rich but the WB read 11.3 to 1?
Here are some pics. https://ls1tech.com/forums/showpost....4&postcount=15
http://vimeo.com/1859232
I worry about the factory main bolts sometimes. I built another shortblock with studs but no use changing until something happens.
Actually I usually hit the tires a lot harder with a 2 step. It went bad a couple of days before I went to spokane, I sent it back to LPE to get it fixed.
I left at 105 kpa, basically 0 boost on the first run.
It didn't list the MPH on the time slip, I think it will be around 116?
It went 6.1 in the 1/8 with a 1.5 60 ft on the first run.
On the second run it did a 6.2 in the1/8 with a 1.7 60 foot leaving at idle (I wasn't ready, confused about the bracket racing thing)
