thinking about learning to paint cars
compressor is the largest part, make sure you get an air compressor that matches your spray gun. 60gal is the smallest size compressor that can be used for spray equment.
and make sure to have a good filter system. you will need a filter at the compressor and one on the gun its self, oh and you will need a air regulator, I prefer to use one on the compressor, but most like to have them on the gun.
remember paint is very expensive, and even more expensive if you screw up.
Buy a super cheap paint like acrylic enamel, and get a messed up body pannel to practice on. you need to get a good DA sander, I prefer a palm sander with hook & loop paper, but thats me. any orbit sander will work fine. for body repairs start with 120G and work your way up to 320G.
the biggest thing to remember is " your paint is only going to look as good as the body work done" Also never go "cheap" on your primer, alot of people make the mistake of buying high doller paint and cheap primer, but your paint is only going to stick as good as the primer.
their is a lot to learn about painting cars, my best advice is to go to a local commuity collage and ask to set in on some classes, or at least go to a local library , they have a few good books on painting. it will have a lot more info, then what I could tell you online.
But when you do start to paint a car, let me know and I will help you the best I can.
Ive been painting cars for 7 years now
Every compressor puts out moisture. that is why you need a filter, bowl filters at the compressor, and disposible inline filters at the gun.
Lowes sells a 60gal Kobalt air compressor for $450. A friend of mine has one and its not bad at all, If I had my pick of compressors for a home shop, I would go with a quincy from northern tool, or an ingersol rand. but the cheapest ive seen to paint a car, is the kobalt.
Sand Paper. Learn your different grits and what each one is mostly used for. Would be kinda pointless to be wet sanding with 480 grit right?
Spay Guns. Definately get a Brand name gun for nicest finishes. the 20 dollar guns from Harbor Frieght arent bad for priming, but thats about as far as they go. Ive paid for a couple guns already ranging from Spray guns that run round 200 bucks to 150 dollar air brushes, so be prepared to spend spend spend, its not a cheap hobby by any means.
Air. I picked up a 27 gal. air compressor for 200 bucks at Harbor Frieght and it works great. I also picked up a inline water filtration system to keep water out of my air from the compressor. These usually have a air regulator to match ANY Spray guns spraying quality.
Lighting. I used to do electrical work and on a jobsite I got a bunch of 4' dual florecent lights free. Already have me a single bay garage framed up back in 1984 by my Grandfather. I put up 13 new lights. 3 on each side of the car and 7 over the car. Lighting makes a big difference to see imperfections in your paint as well as small dings/dents that your wanting to get out, that is if your going to be doing any body work.
Practice. Find old fenders.. hoods.. bumpers.. it doesnt matter. get used to spraying Urethane paint. Clear coats can be harder to lay sometimes for different reasons. Some custom painters I know take their pieces or even the whole vehicle that need to be cleared to a Paint and Body shop just to be cleared after they've done all the paint work.
Ventilation. Have plenty of ventilation. I live out in the country area so not to many people around me. I created a down draft system with 8' duct work, 2 lay in filter grills, a high volocety squirl cage from an old AC house unit, and 10' 6" drainage pipe. works great for pulling the air down around the car.
Prep. wet the ground around the vehicle your fixin to paint. nothin worse than kicking up dust on freshly laid paint. Wipe down your vehicle with a alcohol/water mix to remove anything that may be on the vehicle, such as pizza fingers to oil wrags. You never know what could have touched the car when you werent paying attention.
Space. Have enough room to paint a car and actually move around with out hitting the car. Nuff said.
Also keep in mind about your city ordnances.. its a hefty fine if you get caught painting with out the proper stuff and such. Osha will burn you good.
Hope this helps and definately good info from everyone so far. Take it all in and have fun!
Some pics of my set up so far:
http://www.eastwoodco.com/text/conte...0400-PAINT.pdf
