homade paint booth to paint whole car
Just do an internet search you'll find alot more useful info then this site offers! Most people that paint in their own garage just end up spraying the floor down with water right before you start to spray. Painting/sealing the floor isn't going to remove dust. There is always some dust but most things you can just get rid off when you cut/buff. I'm doing my whole car right now and all i have is concrete garage floor and i didn't even really clean too much and i'm getting good results! Anyways good luck man!!!!
i have painted a number of cars in homemade booths as well as professional booths. The best thing to do is wet the floor and keep it damp. It will keep dust down and catch alot of trash floating around do to the poor enviroment.
My buddy who just painted my car has a full paint booth and shop on his property. It just came out of the booth a few days ago. He has a regular job, and does it as a hobby, but he's used to work at a paint and body shop. His work is professional quality and both he and I couldn't be happier the way my WS6 came out. It took us a little over 3 weeks(with more than a few all-nighters). He cut, buffed, and polished it. He did quite a bit more, but he knows more than I do about the actual process. The Trans Am WS6 was black, but he primered it, sprayed the Copper basecoat, and sprayed 8 coats of Copper Kandy and 4 coats of clear. He's got pics of the project from the very beginning, to the final cut, buff and polish on his camera. Here's just a few of about 100 pics that I have on my camera:
I decided to go with a Copper Kandy w/maple Pearl
I know this is not the color your planning on, but I just wanted to show you the quality of work my buddy did in his private paint booth that he had built on his property.
^^^^ yeah wow at first i wasnt so sure about that color then seeing it in the sun it looks amazing i can only imagine how it looks in person. im thinking of going the route of painting my own car myself so im definately keeping track of this. im also gonna suggest wetting the floor thats why my father told me to do and hes been in th auto repair and body business for 30+ years
Is there any difference in painting the metal surfaces of a car vs the plastics? ie the front fenders, bumpers etc.? these will be removed form the car for all product spraying.
Ive got a pretty good working knowledge of it already but state you opinion, all info is greatly valued, the more the merryer!
#33
were getting all the paint clear primer etc from my Aunt, shes the General Manager of a PPG store. Shes recommended:
DBC basecoat/clearcoat in either omne MBC or MBP
ppg paint
mr187 reducer
mp282 hardener/reduce if it has high and low spots
Keep in mind shes recommending these as good product but also accounting for how and who is doing the spraying, NOT recommending bad *** product that takes 10 years expirence to get right. Plus shes run that store for at least 22 years that I know of so i trust her judgement, lol
ppg paint
mr187 reducer
#34
Sawzall and Welder Mod
Ive done this back when I was a kid... it's not worth it. Just find an independently owned shop that will rent you their booth. $100 give or take is the going rate. The quality will be much better for you in the end and it's not such a pain in the ***. Leave the garage sprays for doorjambs and engine compartments IMO.
#35
OK, absolutely NO heat or flame sources in the booth and also make sure that paint doesnt come in contact with a fan motor. Each of those can result in combustion. Also even if your floor is painted, water will keep dust and debris from flying around, sooo...WET THE FLOOR, it'll also keep dry overspray from flying around. Painting metal and plastics will be the same after they're primered. Don't try to 'bake' the paints after they're applied, again you may cause combustion, and causing a change in conditions can alter how the paint turns out (milky, hazy). You should make sure you paint on a day when the weather is in your favor 70 to 85 degrees and the lower the humidity the better. Warmer days = more thinner and cooler days = less. Also, make sure you screen the paint going into the gun's cup, not the paint going into the mixing cup. When you re-wet the floor, use low pressure on the hose and hold it horizontal and close to the ground to avoid spalshing/splatter, you might need to re-wet the floor between coats. If your color coats come out with orange peel or debris in it, you CAN wet sand it with 800 grit AFTER it dries well. If you get a run, take a razor blade and run the blade backwards along a strip of 400 grit sandpaper (to create a curl on one side) and use that curled side to gently scrape the run down a bit to make it easier to wet sand flat before clearing. Have a good time with your DIY painting!
#36
wow i didnt realize this thread was almost a year old. we never ended up trying it due to the owner of the car changed his plans, although my car is getting a little ragged lol
