Bumper Cover help wanted
Old Jul 23, 2009 | 10:46 PM
VeitSSki8701's Avatar
Default Bumper Cover help wanted
Hello, I am sure this is a common problem for those of you driving the Camaro. Where my hood meets the front bumper cover is a gap. Now this gap is close on one side and progressively gets wider towards the passenger side. What are you guys doing to counter this. I looked and thought I could drill new holes in the lip underneath and pull it back but I dont want to do that. Any suggestions??
Old Jul 29, 2009 | 12:49 PM
2002nbmssdd's Avatar
Raise the hood and u will find two ten MM bolts that are adjustable. They should be right there in between the radiator support and the actual bumper. Loosen both up and u can adjust the gap a little that way. If that does'nt help then your radiator support or frame rails could be bent. Is the gap very wide now?
