Can i pull this out or do i have to replace?
Old Mar 17, 2010 | 08:19 PM
ls1racer1999's Avatar
Default Can i pull this out or do i have to replace?
hey i know absolutely nothing about body work id like to learn a little but i was wondering if it would be easier to replace the whole quarter panel or pop that dent out.?
Old Mar 17, 2010 | 08:25 PM
picture 1 i have better one of the area behind the door i have to find them
Attached Thumbnails Can i pull this out or  do i have to replace?-12430_383030387080_500907080_3681479_3480744_n.jpg
Old Mar 18, 2010 | 06:52 PM
ky_black_ss's Avatar
depends on the dent replacing the quarter panel is a big job and is expensive
Old Mar 19, 2010 | 12:58 AM
BlackWS666's Avatar
replacing a rear quarter is one of the hardest things to do to a car. I would recommend getting a stud gun, and pulling it out. a body hammer, and block can do wonders.
Old Mar 19, 2010 | 04:23 AM
ok thanks alot i would like to learn how to do all that sop i might give it a go with some help. BlackWS666 beautiful car by the way !
Old Mar 19, 2010 | 04:24 AM
lazyboi808's Avatar
Old Mar 19, 2010 | 08:46 AM
SparkyJJO's Avatar
^^ what the heck?
Old Mar 19, 2010 | 09:08 AM
redtransam95's Avatar
do what he says and body filler the rest you dont want to have to replace the rear quarter belive me
Old Mar 19, 2010 | 10:29 AM
black_sheep454's Avatar
Get some professional help from a shop, looks like it would pull okay but if you get carried away trying to pull or push it out you can cause more damage. Since the metals already stretched it's weaker and will stretch easier on the way out, and if it gets stretched out to much it'll be like working on a tin can
Old Mar 19, 2010 | 10:31 AM
BlackWS666's Avatar
yup.. Try to get as much of the metal as straight as possible, and use as much filler as possible. Nothing wrong with using it, just keep it to a minimum. Thanks for the compliment man. I am doing many, many new exterior things to my car, so im right there with you. Also, keep the heat to a minimum!!! if that panel gets warped, its all over. Good luck
Old Mar 19, 2010 | 10:43 AM
Originally Posted by BlackWS666
yup.. Try to get as much of the metal as straight as possible, and use as LITTLE filler as possible. Nothing wrong with using it, just keep it to a minimum. Thanks for the compliment man. I am doing many, many new exterior things to my car, so im right there with you. Also, keep the heat to a minimum!!! if that panel gets warped, its all over. Good luck
Fixed
Old Mar 19, 2010 | 11:27 PM
thanks alot everyone
Old Mar 20, 2010 | 02:50 AM
cjtzcar's Avatar
I am a body man and have replaced a few and let me tell ya, try any thing possible first before you start replacing that panel
Old Mar 26, 2010 | 02:56 AM
Pony Exp.305's Avatar
Originally Posted by lazyboi808
