moulding removal
Old Apr 8, 2010 | 10:29 AM
champain's Avatar
Default moulding removal
hey, i can not find a thread on removing the side moulding on a fbody(98), i want to take them off but dont want to screw anything up,,, do i use a heat gun?
Old Apr 8, 2010 | 10:39 AM
Longshot LCMS's Avatar
There's a million threads on it, just search for it. Lots of guys use heat guns, some use WD 40 and fishing line. Some use goo gone too... there's a million ways to skin that cat.
Old Apr 9, 2010 | 12:38 PM
Endersshadow's Avatar
Use fishing line to remove the molding itself. Then use a heat gun or blow dryer to heat the glue. Remove the glue as best you can (I used my fingers to slowly pull it off). Once you get most of the big glue spots off you should use Goo Gone to remove the residual glue.
Old Apr 10, 2010 | 08:06 PM
NVR_SPDS's Avatar
Its just held on with double sided tape, so i just slowly pulled them off. 2 cars, and no issues.. pulling off the remainder of the tape is kind of crappy, but IMHO it looks ALOT better without them.
Old Apr 10, 2010 | 10:45 PM
Empatho's Avatar
+1
I just pulled them off with my hands, no problem and the tape just rolled off. I did it on a hot sunny day without using a heat gun.
Old Apr 11, 2010 | 12:41 PM
Nightrydass's Avatar
what they said, just be warned that the glue is a mother ******. i have 4 blisters from removing that **** W/ a heat gun & goo-gone
Old Apr 11, 2010 | 12:50 PM
04gtoBMXracer's Avatar
Blow dryer and goo gone. Done this to about 5 cars, any ways that were already suggested should work fine. Just depends on how you want to do it.
Old Apr 11, 2010 | 05:23 PM
9911UZ28's Avatar
just make sure your car was never repainted with the mouldings still on, before you remove them
Old Apr 13, 2010 | 03:19 PM
champain's Avatar
thanks guys, i took em off yesterday, just grew a set of nuts and took em off no chemicals just finger power, looks good!
Old Apr 15, 2010 | 06:20 PM
00NastyZ28's Avatar
i did the same
Old Apr 18, 2010 | 11:42 PM
NVR_SPDS's Avatar
One other thing i did, was to use Meguairs cleaner wax to remove any dirt or wax residue that was built up around the mouldings too.
Old Apr 19, 2010 | 01:14 PM
02CamaroSSLE's Avatar
i need to get off my lazy *** and do this already!!!!
