someone hit me!
Old Apr 24, 2010 | 10:05 AM
msurferh's Avatar
Default someone hit me!
they backed into my driver side rear quarter panel, hit and run........bastard. can i get in there, take off my wheel and everything out of the way and beat the dent out? or should i just take it to a shop.
Old Apr 24, 2010 | 11:55 AM
Fosnot's Avatar
Old Apr 24, 2010 | 11:37 PM
TooFast3800's Avatar
Sad but I want pics!!
Old Apr 25, 2010 | 07:50 AM
1 SIC Z's Avatar
Man I would be so pissed...If there is not a crease in the quarter then you may get by with the paint-less dent removal technique.....As stated pics are needed to be of further help!
John
Old Apr 25, 2010 | 10:01 AM
msurferh's Avatar
Old Apr 25, 2010 | 10:02 AM
msurferh's Avatar
bad pic that i took with my iphone. but it shows the damage pretty good. is it possible to get behind the damage and work it out?
Old Apr 25, 2010 | 10:33 AM
It looks like you can get most of that out but to make it perfect again no, there appears to be a chip in the paint where that black dot it in the pic. You will need a new gas cap for sure.
Why on earth would someone be coming at you on that side of the car to hit you the way they did, I don't know. People are idiots. Sorry that this happened. File a police report and call your insurance. They might fix it without upping your rates if you have the police report.
Old Apr 25, 2010 | 11:52 AM
Irmobaum1999ta's Avatar
Sorry to see that. Contact your local Paintless Dent Repair and see if he will do a free quote Again sorry to see that you got the shaft
Old Apr 25, 2010 | 04:08 PM
msurferh's Avatar
my car was parked and i came out to it, assuming someone backed into my car. there is a little chip in the paint and it would have to be redone. i was just wondering if i can get to the back side of the damage and beat it out.
Old Apr 25, 2010 | 05:56 PM
SparkyJJO's Avatar
His is more reasonable than what someone did to my quarter. I still have no idea how they did what they did to it, or what they used.
I don't think you can get to the backside of the quarter without taking apart a bunch of stuff.
Old Apr 25, 2010 | 07:09 PM
nimrod.sixty9's Avatar
Damn man. Your not too far away so if you find them Ill help with the bodies
Old Apr 25, 2010 | 07:23 PM
ajracing81's Avatar
dont think you can get at the back side theres not alot of room once you get the inter. apart. It also has a sharpe line through it so you cant pdr it. You will need to take it in to get repaired because the metal is stretched where the sharpe line is in the dent
Old Apr 25, 2010 | 07:37 PM
1slo_camaro's Avatar
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
hey man pull the interior panels and get in there with a medium size hammer and take a few soft blows you will still have damage but you might be able to lessen it. or even try your hand to push on it. where its at you should be able to pull the panels off and see it pretty decent on the inside and give it a try.
Old Apr 25, 2010 | 07:40 PM
schram1124's Avatar
Old Apr 25, 2010 | 07:41 PM
ajracing81's Avatar
try pushing with your but i wouldnt hit it with a hammer you may do more damage by trying pound it back out if you havent done it before.
Old Apr 25, 2010 | 08:26 PM
Unertl42's Avatar
I wouldn't use a hammer either, you'll end up messing it up worse, costing you more $ in the long run
Old Apr 25, 2010 | 09:00 PM
jdmotox333's Avatar
i know how you feel exactly but the hit and run but my best friends girlfriend did this 230 am saturday night to my 02 formula 65k miles and well this is what she did
Old Apr 25, 2010 | 09:36 PM
just so you know when i say use a hammer i dont mean take a sledge in there and wake away lol. i mean just give it a few little taps. try with your hand pushing out. i wish i had a pic but ive had this happen twice and one time i could push it out by hand and the other i took a hammer and tapped it out and it popped out no problem.
Old Apr 25, 2010 | 10:51 PM
black_sheep454's Avatar
That sucks, but it could have been alot worse. If you do knock it out some be carefull not to stretch the metal any more. Chances are pdr won't work because of the crease and were the inner structure is for the gas neck
Old Apr 25, 2010 | 11:00 PM
Birdflewls1's Avatar
If i was you i would take off your interior panels if u want the dent out.. take a 2x4 or small peice of wood and and mallet.. do not use a hammer cause it will just make it look horrible and cheap.. u might get most out but sense its by the gas door you cant get it all cause of the hose and such. Paintless dent might be able to get most out but i qoute you at about 700-1000 to fix.. call insurance! they might work with you, its worth a shot
