Is an "airbrush" adequate?
Thanks and sorry for such a newbie question. I've never strayed from a rattle-can before. I want a damned smooth high-gloss finish, so I figured it was time to hang up the ol' rattle cans.
Thanks!
When speaking of compressors, the psi doesn't matter as much as the CFM. 60psi is way to high for any type of spraying that I have ever done. The touch-up gun I have uses around 15-20 PSI. Those little guns work great for spraying small pieces.
This compressor is a 1/8 hp (think I could hook nitrous up to it, I have the spare parts, or maybe I could let it borrow some from my engine). It is rated to 0.7 CFM @ 50 PSI. If I understand correctly, as PSI goes down, CFM goes up. Is there a formula that I could use to calculate the CFM @ 20 PSI?
Thanks again everyone. This is a great break from finals. Now, back to the Roman Empire...
I'll pick up the tank after my final tomorrow! (too bad I have another 2 days later, so no go on actually getting anything done - yet).
Thanks again!
Yes, as pressure goes down, cfm goes up. I just looked on harbor freights website and found a gun that should work for you that is pretty cheap. It wont atomize as good as a good gun, so you wont get as good of a flow. You'll just have to be ready to wetsand and buff everything. It takes 3 cfm@50psi, so basically 6 times the capacity of your compressor. There is another one that is gravity feed that is only 1.5 cfm@ 30psi, but also states that 12cfm is recommended for supply.
Thanks again for all of the help.
I would go and get a small compressor with around a 5 gallon tank. You should be able to get a decently cheap one at lowes or home depot. You will be able to use it over and over again for different projects. You don't want to paint the ground effects a little bit at a time because you keep running out of air. You dont get cfm out of a tank, you get that from your compressor. All you get with a tank is reserve air.
The air brush gun doesn't hold enough paint for what you want it for.
as for rattle cans,,, you get what you pay for,,, I always use to buy the cheap rust paint or value paint and you will never get a perfect gloss look.
If your ganna use rattle can buy the good stuff... rattle cans come with really nice spray nossles now more then ever.
alot of it is spray technique,, so if you cant get good results with a can you probably wont with a gun either.
Also dont rush it.
If u use the good stuff,,, prime, base coat, and then clear,,, letting it dry properly between you can get great results with a can.
Most mistakes ppl make with cans is,, poor spray pattern due to old paint, cloged nossle, cheap nossle or cheap paint, uneven paint application, too dry (not shinny) or too wet (runs), not waiting inbetween coats (pin holes or runs), not cleaning parts or primeing (runs, fisheyes), combining different incompatible paints (cracking, lifting, fisheyes)
Most of the time the problem is too much paint... and some ppl find a gun will lay it on thinner so its harder to get runs. But you still can mess it up with a gun as well.
