Single step gloss black. Would clear do anything?
What should I do!? Thanks.
A single stage will give great shine/depth if you spend enough time on it with sanding/buffing/polishing after the paint is on. I think the single stage gives less UV protection and will start to fade in a few years if you don't keep it maintained.
I think that is right.
the bc/cc is a lot less work after the fact.
You will need an activator to go with your clear if you go that route and its the same 4:1. Most Paint suppliers and/or Companies will label how to mix their products..
