Subframe rail rusted out - fixable or the beginning of the end?
So is this kind of thing reasonably repairable, or is the cancer too far along and this the beginning of the end of my Camaro?
Crap.
I have several new parts for it in the basement too that I've been slowly collecting for the originally-planned fix-up/makeover.
I'm planning on asking the body guy tomorrow to look at it and see what he thinks but I fear he'll say the same as you said
Guess I should say yes it is fixable, but is it financially reasonable to fix. ANYTHING can be fix given enough money and work. But when chasing rust, he warned that such a thing can snowball into a large expensive project quickly...
Driver side rear subframe member - this is the one that was crushing under the weight of the car. You can push on it by hand and it gives.
Floorpan right in front of that
Front driver side subframe
Passenger side isn't as bad as the driver side.
Rear subframe
Front subframe
I do wonder how hard it would be to weld in new sub frames... like what if I bought a rust-free car that had been totalled (front end accident or something) and swapped the undercarriage out, wonder how difficult/expensive that would be.
Its not that bad! you just need to get it to an experienced body man, or shop. The rail that caved in can easily be cut out and replaced. There really is no reason to buy a donor either. either you could talk to a salvage yard and they can cut you out what you need, or someone that knows what they are doing can fabricate a rail pretty easily. For the rest of the rust such as the floor pan and everything else, it all just looks cosmetic from what i can tell. POR-15 would get it sealed up and you wouldn't have to worry about it any longer.
Most of the floorpan is cosmetic, yes. There is one spot that is a tad spongy but the floorpan repairs aren't a big deal really. I already figured that was going to need done.
Hmm. I need to borrow a lift so I can see underneath it and inspect it really well.
Left rear, totally shot and spongy. Right rear isn't as bad but still not too good. Left front is crusty with a few loose flakes inside, but still solid (I use that as a jacking point when I change the oil), and right front is a little crusty on the bottom but not as bad as the other 3. Downside is, all of them - fronts included - have some loose crusty flakes inside, so to fix that all 4 would have to be cut off the car anyway. Sigh. A couple small rust holes through the floorpan under the rear seats but nothing huge.
And I noted a design flaw - the drain holes are stamped from the bottom upward, so when water gets in there it has to be something like 1/16" deep before it will actually drain. Geez no wonder why they are rusting, the water doesn't drain properly. Good job GM
I'm starting to really want to save this car, again. Man why am I so attached to it, just keeps costing me money but I have the hardest time with the idea of letting it go
Maybe it is because I've done so much to it (just to get it reliable, lol) and have so many plans for it... you could pickup another v6 camaro for 4 or 5k ... or even a v8. Have you considered biking? it's fun in the summer
I'm thinking if I do fix this thing, I'll have 3 point SFCs installed at the same time. While doing all that welding might as well put them in then coat it all in POR-15. But that all depends on if I fix it. I haven't decided yet, but I have a long time to decide.
