Painting for the first time.
My hood and rear panel are fading pretty bad, clearcoat peeling off the hood.
I have seen rattle can jobs look halfway descent. Using the Dupli-color gm color match paint code 81 bright red..
I was thinking I could make it look better then what it is by sanding it down, using applying a new layer or 2 of paint then clear coating. Would I be better off re primering it first.
Just want something simple until I can get a Professional paint job. Anything has to look better than it does now, also what is the best grit to use.
Should I sand
Primer
Sand
base coat
clear...or what?
If you do a rattle can job, then have it done professionally, you MUST tell the body shop and they will have to take off everything you did, you cannot spray real paint over rattle can stuff.
Since it looks like (in the back passenger corner) that it's down the primer, you have to sand it down until all the clear is gone, paint the color, then clear. You don't HAVE to primer since you're not covering up any body work or raw material. If you cut though the stock primer to the fiberglass, then yes, you have to primer.
with no experience in the trade at all just gonna "blah" paint your car huh
body work prep work paint work everything in this trade can not be taught online, us techs can give advice little tips here and there but i could never teach anyone online this is a hands on teaching trade not teaching online
so whats the very first thing you do?? dis assemble the whole car everything off......bumpers, headlights tails lights, all the parts on the doors everything that can come off does
working with SMC panles takes experience if there is a small chip do you sand it all the way down to the smc?? nope becasue it will cause a huge divet in the panle, i block the chip out very lightly then swipe a small amount of glaze in the chip
plastic same thing sand to hard sand uneven a divet will be there might possibly warp the plastic i have seen that happen
what do you sand with A D.A. using what?? start with 120 then 180
primer i use ppgs ncp 271
paint guns
tools
sanding blocks
the list goes on and on
just a fyi for ya you hack up your car and then take it to a shop il tell you right it will cost you double the amount of money for us techs to fix your rattle can and bad body work so keep that in mind
not being a dick just honest
