NBM Paint Repair, Touch Up or Re-Spray?
I'm looking for advice on some paint repair for my Navy Blue Metallic Camaro. This is the original 1999 paint. If I was to get this touched up would it look ok? If I was to get this re-sprayed would they be able to match it up without the shade being off? I'm kind of afraid if I got it re-sprayed that it wouldn't match correctly and look like ****.
Thanks guys
![](http://www.hinsonsupercars.com/Pics/FBody/CamaroScratch1.jpg)
![](http://www.hinsonsupercars.com/Pics/FBody/CamaroScratch2.jpg)
Thanks guys
![](http://www.hinsonsupercars.com/Pics/FBody/CamaroScratch3.jpg)
It depends on how it's touched up.
If it's just one of those cheap kits, it probably will look like crap, metallic paint (in my experience) is very difficult to match for chips and scratches.
To get it professionally done, it would have to be resprayed and blended in correctly, it will look great.
But is that worth it?
My advice, is to deal with it, unless you have twenty or more over the car, it totally bothers you and it's a show car.
Also, how many miles are on the car? Do you have the sail panel bubbles? Do you have any signs of clear coat failure on any part of the car? I only ask, is b/c if you want to go for a full repaint, might as well as get everything fixed at once.
These are some of the questions I've been going through, I have some big chips in the hood, a small bit of the sail panel bubbling and some bird etchings that went down to the fiberglass. I figure it's best to get all of these done at once.
Good Luck!
Good Luck!
Good Luck!
Good Luck!
Thanks for your input.
