how to remove emblems?
Old Nov 19, 2010 | 02:29 PM
ElkySS's Avatar
Default how to remove emblems?
anyone know of anything i can use to get the "trans am" emblem without hurting the paint?
Old Nov 19, 2010 | 03:29 PM
layz's Avatar
i used goo gone and fishing line...worked good...
Old Nov 19, 2010 | 04:00 PM
Mike52's Avatar
Here is what I've used for years, Goo Gone. You can get it almost anywhere, your local drug store (CVS, Walgreens, etc), hardware (Ace, Home Depot, Lowes,etc), WalMart, K-Mart, etc.
Squirt a little Goo Gone around the emblem, let it soak in for a few minutes to loosen the adhesive, then use a thin string like fishing line or even dental floss to get behind the emblem and using a back & forth sawing motion, finish cutting the emblem loose. Once the emblem is off, use more Goo Gone to remove the remaining adhesive residue.
Mike
Old Nov 21, 2010 | 01:44 PM
2002nbmss's Avatar
3m makes a stripe wheel that is rubber and fits in a drill chuck. It won't hurt the paint if you don't bear down on it just let the wheel do its job. I use one every day in the body shop
Old Nov 21, 2010 | 03:21 PM
omarrakeen's Avatar
i used my ID jst move it behind the emblem and its gone...then spray some of the ^ said above and ur good to go.
