LT1 Bird-Satin Black...157.66 dollar paint job
01ssreda4,
My John Deere Blitz Black was $38.00 a gallon and $32.00 for the hardener. I don't know how to paint myself or it would have been less than $200 also. Sanding, dent removal, and primer on the bad spots, tack coat, and two full wet coats including door jambs and bottom of doors was $800.
If you don't like it fine. We can't all have a red Camaro afterall.
I don't have any friends around here that are accomplished shutterbugs. I went to high school with a guy who is a professional photographer now for Ft. Benning in Columbus, Ga. but that is 3 hours away..........
I hope not to hijack your thread, but I have one question. Im going to do the same to my car in the beginning of the year I hope. Will the Dupli Color Satin Black Do the trick? Im gonna take my sweet time using spray cans, maybe just buy the gun that attaches to the can.
#34
so, OP, you said you used your friends' dads' equipment, meaning you used his booth? or was this an "in garage" job. im looking to do this exact same thing on a 00 camaro, and wonder if im going to run into any dust problems if i use my garage.
#35
we used a garage
the thing with the kirker paint is that it is a lot thicker than normal paint...so you have to have the gun at 60ish psi...and when we did it...there was very little overspray/dusting compared to a house of kolor job we did prior that left the entire garage blue lol
#39
looks good, I flat blacked my 02 corvette. it shows marks from people rubbing up against it and such. I use lemon pledge in a spray can (funiture polish) and it really makes mine look good. I put it on and let it soak then just spread evenly. FWIW i used shopline epoxy primer
