Need Tips..
Old Mar 19, 2011 | 01:03 AM
Chuck_01's Avatar
Exclamation Need Tips..
What would be the easiest way 2 paint some stock snowflake camaro wheels.. tryin 2 go black..
Old Mar 19, 2011 | 01:06 AM
xX-Z28-Xx's Avatar
You have to sand em down and start over with a gloss black.
Old Mar 22, 2011 | 09:23 PM
Chuck_01's Avatar
Aight will do.. Also i have a cracked front bumper.. the crack is about 6-8 inches long right where the fog is at to where the wheel starts.. wut could i use 2 fix it..? Bondo maybe or would fiber glass be tha way 2 go.. Note that its a plastic bumper..
Old Mar 22, 2011 | 09:54 PM
The Mighty Texan's Avatar
I have a crack there too that needs fixing, haven't gotten around it it yet though. For the wheels, yeah just sand or sandblast then paint or powdercoat.
Old Mar 23, 2011 | 12:16 AM
SinisterZ28's Avatar
3m makes plastic repair stuff,u have to sand the back and front of the bumper,then u put a patch on the back and sqwert the 2 part plastic repair,let it dry sand with 80grit then fiberglass,plastic filler(bondo),putty,then primer to do it right,may not need fiberglass,but the problem is the gun for the 2 part adhesive is like 75 dollars,and paint,probably b easier to get a bodyshop to fix,some times they will cut u a deal if your willing to get it spotted in instead of painting the whole bumper,but u sacrifice how good it might look,but if its down low it might not b noticed
Old Mar 23, 2011 | 12:22 AM
Go to your local paint store and they might recommend some different products,also I'm assuming it's a tear,if it's just paint cracked then sand with 180 then primer,sand primer w 320,then lighty w 500wet then paint
By Brett Foote | 2026-06-04 05:00:17
