Time to paint the block... how to remove old paint?
Old Mar 21, 2011 | 01:35 PM
L33_944's Avatar
Default Time to paint the block... how to remove old paint?
I've got a cast iron block and the stock black paint is starting to flake and rust... while i've got the motor out i want to paint it... should i strip ALL the paint off? or just use CLR or something to take the rust off and chip away as much of the old paint as possible, scuff it up and paint over?
i've heard dish soap/hot water is good for removing the grease too.
Any advise would be appriciated.
Thanks,
Jeff
Old Mar 21, 2011 | 02:50 PM
McNord's Avatar
Ive used wire brushes in the past & then use some kind of degreaser.
Old Mar 26, 2011 | 01:01 PM
gringo dfw's Avatar
purple power not diluted and rinse with power washer then a few different wire brushes on a drill. should take it down to bare then paint.
remember to spray the internals liberally with WD-40 BEFORE taping up to paint. dont want that **** to get rusty
Old Mar 26, 2011 | 09:57 PM
AutoRodTechnologies's Avatar
i usually go over the blocks with aircraft stripper, then a purple power or mean green type degreaser to neutralize the aircraft stripper, then wash clean.
Old Mar 28, 2011 | 09:41 AM
great421's Avatar
Easy Off oven cleaner FTW!!!
Old Mar 28, 2011 | 11:29 AM
bstuby's Avatar
They sell goof off graffiti stripper and works awsome. Dont know how it would work on blocks tho. its about 6 bucks a can. spray on and wipe off
