Exterior Door Panel Coming Loose
Hey guys maybe you can help me out. I just bought a 2002 Firehawk and noticed when I got home that the outside door panel is coming loose, which is causing the driver side t-top to leak because its not pushing the window hard against the weatherstripping.
Is this a common problem and / or does anyone have a quick fix? It looks like all I need to do is apply some adhesive to make it stick again. Thanks.
get in touch with the local paint shop they can teell you what body shops are useing to glue it back with probably 3M 8015 panel bond or Fusior panal glue,havent really done it but i know it happens,we just dont get but 1-2 f-bodys in our shop a year
What side/end of the door. If its the rear/lock side than panel bond. If its the top front pull the mirror and mirror bracket and replace the rivet that holds it to the door frame.
