worth fixing? c5 vette
You can probably get a good shop to spray the front clip and blend the door for about 1,000. Most frame shops have a 4 hr minimum, I'd expect the frame work to cost you $200-400
I'd part it out persoanlly. Youll make a profit doing so.. then you can take that $$ plus whatever yould dump into this one to fix it, and buy one that doesnt have a salvage title. If it werent for the salvage title it'd be worth fixing IMO but theres just too many inexpensive C5s already out there to mess with one thats branded as such.
Whatever you do.. good luck with it!
as for parts and suspension wise, never think anything is good, little things pop up all over the farther you get fixing. and trust me things always come up, ive fixes a number of big hit cars they all seem ok at first hahahaha
as for the drivers fender if its miss aligned only because of the frame, its swayed prettttty good, but IMO a good experienced frame guy will be able to pull it
start pulling the front end apart and make yourself a list of the parts you need and find them yourself, make sure to go though with a fine tooth comb
me personally id fix it
