CETA Mod
Decided to finally do the CETA mod to the 96 WS6.
Materials (All from Wal-Mart)
100 grit sandpaper - $5
Sanding block (Not required) - $5
Blue 1" Painters Tape - $5
Clear plastic tarp - $2
2 cans Krylon Fusion Satin Black - $10
Note: All prices are random estimates... don't have the receipt on me.
TOTAL COST - $25-$30
There are very detailed guides on the internet explaining how to do this with many steps. I skipped most of them.
1. I backed my TA up on some cheap ramps to make it easier on my back while working
2. Remove the license plate (4 screws)
3. I used 100 grit sand paper to get rid of the clear coat in the area I was painting.
4. I washed the area with simple water and a rag.
5. Let it dry completely (Takes only a minute or two if you are just wiping with wet rag)
6. Begin taping the line around where you will be painting. Make sure you take a bit of time with this... you don't want your lines looking sloppy.
Picture of bumper sanded, washed, and taped.
7. I draped the tarp over the rear of my TA and taped it down. It was a slightly windy day and I didn't want overspray reaching my car anywhere. I also cut a bit of this to wrap around my tailpipes (even though they're black already...)
8. Time for the fun part. Spray the entire bumper in a light coat, in full sweeping motions. Never stop your spray on the bumper if possible.
9. Let the coat sit for 15 minutes, then repeat. Make sure you do light coats, so the paint doesn't run. I ended up doing 5 light coats.
This pic is after a few coats.
10. Let sit for a few hours (I let it sit for 3-4 hours), and remove tape/tarp. Krylon Fusion dries very quickly, so 3-4 hours is all it really needs to harden. It wasn't even sticky 20 minutes after my last coat, but I didn't want to push my luck.
11. ENJOY your nice new rear bumper.
I'll try and get some good pictures in good light next time I give it a wash, just so show how the paint finish turned out. Looks great in person. Also gonna buy some VHT nightshade and try to hide the lamination issues with my tails. Hopefully it works.
Also I would recommend tinting your tail lights with a true clear coat/black base coat mix and not that niteshade crap. May cost you a little more if you have to pay someone to do it/do not have a spray gun and materials but the quality difference is astounding.
Oh well, I guess these cars are too old to be taken care of properly, until they're ready to be restored.
800 will work, as will 100. If you can tell no difference, what does it matter?
Nope. If you are going for a gloss finish I would definitely recommend wet sanding in between every other coat as well as applying a nice clear (Also, using a much higher grit sandpaper originally... 100 grit is NOT for gloss). With the satin finish, it's not really necessary. (Clear is optional for durability)
that cracked me up, Chaman your car is sick man, Best looking bird on tech,
