Clearcoat question
Old May 22, 2011 | 01:29 PM
waxenate's Avatar
Default Clearcoat question
Ok...I have a 95 Z-28 that I am repainting. It is yellow BC/CC. Some of the CC is peeling. Do I need to completely remove the CC or just blend and seal then prime?
Old May 22, 2011 | 02:36 PM
LSwonMatt's Avatar
you will have to feather edge out the clear coat otherwise if your going to prime any it will peel off just like your clear is doing... best thing to do is da the whole car with 180 and primer so you start with a good foundation
Old May 22, 2011 | 04:31 PM
SinisterZ28's Avatar
Here's another tip when doing yellow use white sealer before you put the yellow base down or it won't cover for **** n look green
Old May 22, 2011 | 05:19 PM
223HAWK's Avatar
YES!!!
It doesnt matter what band of Paint...Yellow doesnt cover at all!
Old May 22, 2011 | 09:59 PM
waxenate's Avatar
Thanks guys. I'm actually covering the yellow with a dark metallic grey. So just smooth out the areas where the clear is peeling and prime?
Old May 22, 2011 | 10:30 PM
dreemurY2K SS's Avatar
U can just featheredge it with 220 and seal it and paint it, primer is only nessecary when there is raw bondo somewere...hope this works go 220 then 400 then seal and paint =)
Old May 22, 2011 | 10:34 PM
Check out my thread I painted my friends ws6 pearl yellow with black
Old May 23, 2011 | 07:35 AM
waxenate's Avatar
I have a few areas that I am going to use some icing. Should I do all of that before I seal? Sorry...total newb! Lol This is a father son project and we are learning as we go. Thank god for this site!
Old May 23, 2011 | 10:45 AM
LSwonMatt's Avatar
yes you can seal over finishing glaze
Old May 23, 2011 | 12:00 PM
Macs98Z's Avatar
Best advice yet. DA or sandblast the car down to the factory primer and then prime the car. For all the work it takes to do any paint job, it's best to do it right the first time. You will thank yourself five years down the road when your paint still looks good. In not taking the old clear coat off you are taking a chance that the paint you're putting over top of it may not last very long. If the old clear coat is peeling in one spot, it probably means other areas are starting to weaken too. JMHO
Old May 24, 2011 | 08:45 PM
180 is a rough grit to just take off clear coat, that will leave deep scratches that later u still need to hit up with finer and prob have to primer..
best thing to do imo is hit it up with 220 all of it u will take off all clear and even some paint, is rough enough to take off unwanted clear and not leave very deep scratches..
after the 220 go to 320 then primer the needed areas, and hit it up with 400 dry or wet and you will be ready to seal...
this is the thread of the ws6 i painted...
https://ls1tech.com/forums/western-m...-together.html
