97Camaro Lt1 Swap to 94Camaro V6 body
Just trying to figure out if its possible to swap an lt1 into a v6 body? If so what all needs swapped out? Are the wire harness the same or would they need swapped out as well.
not sure about the lt1 but did the v6 to ls1 and this guide helped alot. They will also talk to you on the phone to help with the problems.
http://www.tacreationsusa.com/3_4_3_8_v6_to_ls1.htm
Ya you will need to change the body harness and engine harness. It will be best if you have the engine cradle and all and just slap it in the body. Just disconnect the shocks and six bolts to drop the cradle. It's pretty easy I have done the swap twice.
![](http://i1127.photobucket.com/albums/l635/nickcollias/b63295ef.jpg)
