What material should I use for pastic repair?
Im trying to modify my gauge cluster bezel and I am adding some plastic to it. I will be attaching the plastic with 2 part epoxy that I have but what should I use as a body filler? to make the nice contours and such? I heard If I use regular filler it will eventually crack. so what is the next cheapest alternative?
Though a ton of people use it, and I suppose it does work fine(short term lol ), its just not suited well to fabricing with plastic and its adds alot of weight. Bondo is heavy and it can crack over time. If you must use body filler, at the very least, use super fine 3m filler. The bondo brand stuff is complete junk and its 10 times harder to work with.
Heres a link to the dynatron stuff if you were interested. The right products may cost a little more, but long term durability and ease of use more than make up for the headache mess of using body filler on flexible interior plastics.
http://www.strobelssupply.com/3M?product_id=35055
