Which sanding paper?
Old Apr 14, 2012 | 06:19 PM
2QuikTA's Avatar
Default Which sanding paper?
If I just want to take off 1 coat of rattle clear, what grit should be good?
Old Apr 14, 2012 | 07:56 PM
critical.in.ga's Avatar
What is under the rattle clear?
Old Apr 14, 2012 | 09:21 PM
98camarols1's Avatar
what are you trying to accomplish?
Old Apr 14, 2012 | 10:10 PM
2QuikTA's Avatar
Well, I'm trying to paint my lower airbox. I sanded it down for the most part but didn't get all of the texture in some spots. Sprayed a gloss black and came out fine, you couldn't see/feel the spots that still had slight texture. When I went to spray some clearcoat, it cracked in the spots that the texture was still there. If the top coat looked good though, I don't understand why/how the clear would go on bad if the top coat didn't.
Old Apr 14, 2012 | 10:34 PM
Jr.Samples's Avatar
40 grit on a d/a J/K I would try 1500 wet and see if that would work.
Old Apr 14, 2012 | 11:05 PM
you can sand it with 800-1000 and reclear it
