What's this glue under...
Old Sep 4, 2012 | 02:04 PM
Exitstageleft's Avatar
Default What's this glue under...
What are they using as the glue-tar-like black stuff under the center black rail between the t-tops? I'm going to need to repair part of it and want to make sure I buy the correct stuff for when I reassemble it.
See pics...
Any guidance would be greatly appreciated!
Attached Thumbnails What's this glue under...-imag0865sm.jpg   What's this glue under...-imag0868sm.jpg
Old Sep 4, 2012 | 03:08 PM
CayenneRedV6's Avatar
That's just a double sided foam like tape.
Old Sep 4, 2012 | 04:40 PM
it's more than just "foam like". It seems to be more taffy-like.
I guess I'm specifically looking for the product itself.
Old Sep 4, 2012 | 05:48 PM
00ultraz28's Avatar
If its like a hard rubber it probably a urethane ... if its uniform strips and if still soft and sticky its probably double sided tape ... double sided tape that holds mouldings and sufficient on isn't like a foam tape. .. you can run up to a local body shop and they will most likely hook you up with a fee strips of double side for cheap
Old Sep 4, 2012 | 05:50 PM
00ultraz28's Avatar
I should start proof reading my post ... sorry for some of the illiteracy... my phone likes to type stuff on its on
Old Sep 5, 2012 | 06:45 AM
I've pulled that off before and it was just double sided tape. If yours is tacky I don't know why or what to tell you.
By Brett Foote | 2026-06-04 05:00:17
