Body panel adjustments?
I just did a front end conversion to my 95 Camaro. Using all GM parts it all bolted up just fine but now I'm at the point where I need to start adjusting everything slightly to make the gaps perfect. My question is where the hell do I start? What part do you do first? I'd assume the hood and then everything is setup off of that?
i always start with the fenders to the doors. you didnt move the doors so you know they are where they need to be. get the gap right there then start with aligning the hood. just make sure your fenders are square before you set your hood. the fun part is the headlights, that will take some fine tuning to get perfect.
