Rocker Panel Extension
I would give these people (http://www.hawksthirdgenparts.com/) a call. They are great to deal with and have tons and tons of salvaged F-body parts.
Sawzall and Welder Mod
If you're lucky you might even find one in pewter! Heads up on removing it.. There's a line of 7mm screws on the bottom and then some hidden 10 or 11 mm nuts that you have to access from inside the front fenderwell. This requires removing the front wheel and loosening the back of the fender liner for access. After that the rocker extension ( side skirt) just pulls off.
