door removal questions
real question is, if i take my WHOLE door off the car to do all this so its in my garage and i have the room to do it etc, what issuses could i have? things ive thought of were....
1. is the door being shut on the car help hold the integrity of it/will it hurt the rest of the body at all with out the door on it for a few days
2. how hard would it be for a friend and i to remove/reattach the door and have it line up ok and shut like before
3. would i have to make quick disconnects for all the wires or are there connects close by that will pull through the grommet?
also dont know if this should be in body section of ls1 forums or not but
The structural integrity is in the jamb itself. Both pillars being tied together by the rocker and roof panel.
With the harness removed... If you pull the fender off, close the door (window down) and remove the 4 bolts in the 2 brackets. Then with your body against the door pull the handle lightly, lean it towards you, one hand in the door (wear gloves) and you can move it freely by yourself.
I re-install them the same way.
Really only thing you have to worry about is dropping it / scratching the bottom.
You could make quick connects... are you planning on doing this often? if its just once, then i wouldnt.
So my understanding is that the best way to go about it is to remove the fender and that there is a harness conector for the door harnees so disconect that, then remove the four bolts holding the door then the whole thing comes off.
Am I missing anything?
so i have to remove the door and re attach that. where is the door harness pigtail behind the fender? or under the dash area Trending Topics
As for door alignment I no longer have the same 2 doors that originally came with my O2 TA theyve been replaced with a 95 firebird door and a 97 I think. Once removed they will never sit right IDC how much you tweak windows and the 4 bolts ....if u have issues use the trim as a guide with a jack and a piece of woon on the bottom of the the door to match(one man)(or be a jerk and make your friend hold the door inplace if you think thats to neandrathal like I did
) to the read quarter panel and you can also control the tightness of the seal around the door by adjusting the double bar latch on the rear quarter ie if you pull it out the tighter your door will be and the further in the looser.... if its too tight the window will roll up slower due to friction but on the upside it doesnt leak
GL
