hit pole with rear passenger tire, tire crooked out what could be wrong?
i hit a pole with my passenger rear tire while pulling out of a gas pump, the tire is crooked out and we tried to get the wheel to straighten out but it only moved the slightest bit. my dad thinks that it is the trailing arm since the other rear tire's trailing arm is angled a little and the side i hit is completely straight. which would make sense as to why it is bent. However, if that is not the problem what else could be wrong? everything else looks perfectly fine. Also, if anyone knows what it might cose to get it aligned at a shop, it is a unibody. thanks
If your lucky just a damaged rim, worst case scenario damaged axle.
