Where is my paint code on my 2002 Camaro ss?
LS1Tech Administrator
Received 1,692 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
As noted it's usually listed on the RPO (sticker with a lot of 3 digit codes) at the bottom. GM usually uses a code like this: "BC/CC WA 5538". It may sometimes not say WA, and not the 5538 at all, GM is not consistent always. You can also look for in the RPO codes for a code that ends with L or U but must have the first two digits being numbers. So back to our example you may see:
"BC/CC WA 5538" and in the RPO codes may find something like "33L". The 5538 is more accurate code whereas the "33" is a generic code that will just give you a list of ALL paint codes (could not even be all reds for example) assigned to that code and would have to sort through for your model in the database.
Location will vary on each vehicle. Check areas like the glove box, center console, and drivers door jamb. Other areas like the trunk, and underhood are common on some vehicles.
Also out of curiosity why did YOU have to find the paint code if you brought it to a body shop? That's their job. Also if your sticker for your paint code is missing there are methods the body shop can use to still look up the exact code and your paint variance.
Well the guy was looking around to find it and I thought it was in the door jam myself. Looked in the glove box, truck, center counsel everywhere. coudlnt find it. So we just took the Vin, reason i helped is because I thought I knew where it was myself. I swore I seen it somewhere but I guess I was wrong. I was just getting my CME painted. Hopefully today ill post some pics if not today Def tomorrow
Thanks for all of your guy's help. ill keep looking for it
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
This is where it is on all 4th gen fbodies. If it isn't, your sticker either was removed, painted over, or something.
I always thought putting important stuff like that on the door was a stupid place. Get in an accident that requires a new door and now you've lost all your stuff since you can't get new stickers. My Trailblazer has the RPO code sticker in the glove box which is a much better location IMO.
Yeah having it on the door is a silly location as you said. The manufactures should really place it in a more not so easily replaced area (like the cowl/etc.) that if wrecked the car would probably be totaled anyways at that point not a door. There are ways to get a replacement sticker, but it is NOT cheap by any means.
camarodude87, if that is a decent paint shop there are still several other ways to acquire a paint match without the code.
I have owned several 4th gens, and worked on dozens. I have never seen a single '98+ car with the SPID sticker in the glove box.
