T-Top vs hardtop structure.
The 4th gen cars were designed to have ttops.
I believe there is a difference, but its so small thats its not measurable.
A properly setup 4th gen will be rigid as hell. (mine
) Hate to say it but 700hp now isnt like 700 hp used to be.
Much more common with all the turbo builds we have now.
The car will only flex if you can put that 700 hp to the ground.
Get some strut frame connectors, tubular torque arm, panhard bar, and lower control arms and you will be fine.
Better yet, find the threads where guys convert to Ttops and look at the thin metal that they cut out.
Interesting about taking t tops off at the track. Seems like that would cause aero disadvantages toward the end of the track that may slow one down even more.
there is extra rigidity to be had from the metal bracing on both sides of the car on a hardtop car, though...many people say it's negligible, but if you're into cornering at all, even that thin sheet metal will cause the top to flex a lot less than it would if it were a t-top car, especially if you're hard cornering at road race/auto-x events on really sticky tires. welded subframe connectors, sway bars, and a shock tower brace will all reduce how much flex there is during hard cornering, but every little bit helps, right? something is better than nothing when it comes to bracing.
