Manual Window Conversion ('00 Firebird)
If anyone has any experience, post it up!
https://ls1tech.com/forums/chevrolet...onversion.html
As for the fastening of your actuator goto Home depot or lowes and get some fender washers and bolts with lock nuts put a washer on the insde and outside if you can I used lock tight to hold them in place on the inside this way when you tighten them down the washer will displace the force on the fiberglass and keep them from cracking UNLIKE RIVETS......DONT USE RIVETS CANT STRESS THIS ENOUGH.....ESPECIALLY IN AUTOMATICS.....be very careful when drilling them out .... and haveing bolts will allow you to easily replace something if you need or to go back to automatic.......the holes which youll use will be different because the actuator for a manual arm is shorter use the larger hole where the handle axel will go as your guide ....remember everything is flipped on the inside so keep that in mind as a helpful aid and the spring is a PITA if you have to hook it on the actuator yourself......I might still have mine laying around I can take a picture of for you as a guide no promises
