Fender help
Old Feb 20, 2014 | 06:26 PM
TranAmMando's Avatar
Default Fender help
Hey guys I am a newbie!
This is my 1st post. My problem is I put on a new OEM fender and the door is hitting the fender when you open the door. I know the fender needs adjusted. The guy who put it on wont come and adjusted it can someone please help me! Thanks guys
Old Feb 23, 2014 | 07:11 PM
nastybuzzard's Avatar
It is not that difficult to adjust it yourself. I just replaced my passenger side fender which was cracked with an oem replacement fender and even when I first installed it, it did the same thing as yours and rubbed the door.
After a couple hours of messing with it, I just loosened the bolts up and pulled the fender forward some. It does have some adjust-ability.
Old Mar 5, 2014 | 12:02 PM
TORK?'s Avatar
Check out this thread an maybe it will help. If the tabs on the bottom are bent from a jack or whatever this could be the case. Has happened to a lot of us
https://ls1tech.com/forums/paint-bod...-gap-pics.html
By Brett Foote | 2026-06-04 05:00:17
