SS Hood vs Z28 Hood Weight?
Hi,
Looking to get an OEM SS Hood for my 2002 Z and I was curious what the difference is in weight.
I've read that the SS is more, that the SS is less, and that the SS is about the same which pretty much covers all the options, so if anyone with actual weights could chime in, I woudl appreciate it.
Thanks!
From the Weight Reduction Thread stickied in the Drag Racing Tech section:
Looks like the steel hood is just slightly heavier than the SMC Super Sport Hood. I've carried both and the SS hood did feel lighter, but that may just be the placebo effect. I believed that the SMC hood would be lighter and so my perceptions when handling the hood made it seem that way to me to confirm my beliefs.
Looks like the SS hood is not going to be good for weight reduction, but at least it's not a weight gain.
z28 hood
I just weighed my 99 z28 hood ,I came up with 91 lbs with out the insulation and the generic ss hood with lots of body filler to get it straight weighed 33lbs my s10 steel hood weighed more then 47lbs
I wonder if the quoted weight in the weight reduction thread fell victim to a keystroke error because 52 and 91 is a pretty significant difference. Just so I'm sure, you did mean to say 91lbs right tsteel1?
Yes im positive
I take a lot of junk to the dump I have scale right in garage i've junked a couple of these hoods there right at 100lbs the person who said 42 come on they way more then a big bag of cat litter I can get the hood off by myself but its a pain without a second person they have a double layer steel frame in them I can tell you there is a weight reduction with the fiberglass aftermarket hood don't know with the factory SS one
Hmm, I wonder if the 51 lb quoted weight is accurate for the 98-02 SS hoods? Sounds pretty close to what you found for the 97 hood.
