painting ls6 intake... questions
just picked up an ls6 intake off a forum member, had some questions about the rattle can process. read through a few write ups, and I have an idea of sanding and when to. haven't really sprayed much, but think I have a concept on correct layering and such.
now on to my questions.
1. I plan on using an adhesion promoter. I figure 1-2 fairly light layers should do. but how soon after that can I start spraying the primer?
2. after I get the last layer of primer on, I'm assuming that I let that dry for 24 hours before I lay on the base coat?
3. color choice, I get it is all personal choice, but my z is arctic white, and I am kind of interested in doing a gloss white intake.
I haven't been able to find a picture to see if it actually looks good in the bay or if I should do black or charcoal.
4. I'm no professional but it seems as long as I don't completely botch it, I can get a glass finish. for those that have painted there intake light/bright colors, does dirt stick to it easy? or is it easy to clean.
5. bonus question, can you pull off the center console and sand it and paint it?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Since I paint cars for a living, here is what I did.
1. cleaned intake from all oil, dirt or whatever is on it.
2. used wax/grease remover to get rid of any residue that was left behind from whatever chemical you used to clean with.
3. sprayed 2 layers of adhesion promoter
4. waited 15 mins to dry, then sprayed base coat.
5. waited another 15 to dry then sprayed clear coat.
6. waited 8 hours before I installed it. then, you sir, are finished.
Now I could have sprayed primer if I wanted it to be a flawless smooth finish (if so, wait at least an hour before you sand the primer before you spray the base coat) but I didnt see myself putting that much effort into it this time around. I really liked how it turned out. Hope all goes well!
If you search for painting ls6 intake a few threads come up with different processes
