stripe info
Old Jun 19, 2014 | 07:25 PM
98amy's Avatar
Default stripe info
I need measurements on stripes on a ws6. please help I want to paint them on.
Old Jun 20, 2014 | 12:36 AM
justin455's Avatar
Douchebag On The Tree
What do you mean?
Only one WS6 ever came with factory stripes and that was the 30th anniversary model. If those are the stripes you need dimensions for, hopefully someone will chime in with those. They look like this...
If you just mean regular stripes going down the bulges of the hood, there are not set dimensions for those. You just have to follow the shape and contours of the hood, and then tape off your design. Otherwise I do believe you can order some in vinyl that would be trimmed to the size you need. Then you just apply them right on.
That would be something like this.
Of course you could also mean blackbird stripes. Which, I do believe, those can be ordered in vinyl as well. Or just taped out onto the hood and painted. They look like this.
Will a little bit more clarification would could help you out more with what you're wanting.
Old Jun 21, 2014 | 12:26 PM
98amy's Avatar
I want regular stripes on buldge of the hood,if anyone one has them please post up close pics and if you can measure them. I don't want vinyl.thanks
Old Jun 21, 2014 | 04:22 PM
justin455's Avatar
Originally Posted by justin455
If you just mean regular stripes going down the bulges of the hood, there are no set dimensions for those. You just have to follow the shape and contours of the hood, and then tape off your design.
Old Jun 21, 2014 | 08:26 PM
topgun1851's Avatar
Dude, if u r painting them, u can do anything u want and any measurements u want. If u want them the width of th bulges, just measure the bulges. Pretty simple.
I painted mine also, and came up with something different
https://ls1tech.com/forums/appearanc...t-ls1tech.html
Old Jun 22, 2014 | 09:05 AM
98amy's Avatar
im not a dude. I just wanted to make sure there wasn't any measurements on stripes.thanks for the help.
Old Jun 22, 2014 | 09:18 PM
Death trap's Avatar
Just do what looks right to your eye. Chances are if you measure both sides of the hood strips on the same hood, they will not be perfectly even or symmetrical from side to side. The vinyl stretches and shrinks differently on either side of the hood as it's put on.
Old Jun 23, 2014 | 01:15 AM
Zerokube's Avatar
that made me laugh
I plan on actually using some plastidip on my hood and i plan on doing a few different things, i'll make sure to take some progress photos and post em. But just use plastidip and just use painters tape and make your own
Old Jun 23, 2014 | 07:05 PM
98amy's Avatar
painted them on took 4 hrs to measure.looks good.if want to see pics go to my car,yes they are bright pink.
Old Jun 23, 2014 | 09:32 PM
Death trap's Avatar
Stripes came out nice, knew you could do it!
Old Jun 24, 2014 | 07:11 PM
98amy's Avatar
thanks
