1999 F body core supports
Old 10-23-2014, 09:40 AM
Joel LeNoir's Avatar
Question 1999 F body core supports
Hello, could someone tell me the difference between a firebird and camaro core support around the headlight area. Pics would be great.
Going to make custom headlights for my trans am and I believe the camaro core support will fit the bill. Need the camaro's headlight mounting points.
Thanks for any help.........
Old 10-23-2014, 12:58 PM
Daniel Richards's Avatar
I may be wrong on this, but I don't think there is a difference.
if you look closely in the pictures in the first post of this thread https://ls1tech.com/forums/paint-bod...transmaro.html you can see the RED core support that matches the red rocker panels (another part WELDED to the car), which would leave me to believe that car was originally a red camaro that got a whole T/A front clip.
90% of the differences (outside of the body lines) are the brackets that attach to the frame rails and core support to allow the different body panels to fit.
Old 10-23-2014, 05:27 PM
Spartan7's Avatar
There is no difference in the subframe, the difference is in the parts that bolt to it. Even 93-97 cars are nearly identical.
Old 10-24-2014, 04:05 AM
Thanks for the replies. I guess I need to find a GM sheet metal book from 99. Will look online as well. Gots to be out there.
Old 10-25-2014, 12:19 AM
LT4vert's Avatar
Very true. The entire front clip structure including the core support is the same between the Camaro and Firebirds, including the mounting points.
Quick Reply: 1999 F body core supports
