Some surface rust
Old Jun 7, 2017 | 10:25 AM
Mikey SS's Avatar
Default Some surface rust
I have some surface rust under my car. Someone suggested using POR 15. Anyone have any experience with this? Any advice would be appreciated.
Old Jun 9, 2017 | 01:42 PM
bleepster's Avatar
i had some surface rust on mine - nothing bad. I used the POR-15 system. i did mine 2 years ago, and it has not come back. Need to clean thoroughly and dry thoroughly.
i put mine on with foam brushes
Old Jun 9, 2017 | 02:23 PM
Mikey SS's Avatar
Thanks for info
Old Jul 22, 2017 | 01:26 AM
ZeeTwentyFate's Avatar
POR stuff is **** man, ive never had rust come back after 7 years
Old Aug 19, 2017 | 12:18 PM
lowchevytrucks8503's Avatar
I have been using POR15 on my '85 C10 and so far love the stuff. I have been using foam brushes too and after getting a quart size can, I have since been getting the pint size. It goes pretty far but dries quickly. I also drilled a hole in the can and put a bolt into. Easier to pour a little out of it instead of taking the lid off and trying to get it back on.
Old Sep 2, 2017 | 07:54 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Been using POR15 for many years. Up here in the northeast Ohio rustbelt,it's difficult to keep things rust free. Get it on your skin/clothes,it's permanent,use lacquer thinner for skin immediately. Once cured/set on iron/steel,it's very tough and resistant. I mainly use it on rear ends. Doesn't work well on bare clean metal,needs to be treated with their 'etching' compound or wet the bare metal with water to create a natural orange patina. Interacting with a molecular rust surface is part of the curing process. A freshly opened can is very 'watery' and not thick like paint. Has excellent penetration.
Old Sep 7, 2017 | 07:46 AM
Mikey SS's Avatar
Awesome man thank you. I'm in NJ so I feel your pain on the rust
