Plastic trim restoration
Old Mar 30, 2018 | 06:19 PM
Deniz A's Avatar
Default Plastic trim restoration
What is the best way to get rid of these scratches?
Regards
Old Apr 2, 2018 | 02:50 PM
Viper's Avatar
STEP 1: Clean the plastic surface to remove any dirt or debris.
STEP 2: Using a heat gun, put the heat to about half and warm the scratched surface until it is soft and mushy. NOTE: Make sure you do not overheat the plastic as you WILL burn it.
STEP 3: Apply a grain pad (around $7 dollars) to the plastic surface as this will re-texture the plastic. NOTE: Be careful when doing this step as the plastic will be very HOT!
STEP 4: After applying the grain pad, let the plastic cool and sand with superfine sandpaper to smooth it out if needed.
Old Apr 3, 2018 | 07:26 AM
Deniz A's Avatar
Thanks a lot m8
Old Apr 30, 2018 | 07:47 PM
toplessHO's Avatar
Ive done same thing but without the pad
using a thick cloth and slapping with a wire brush
If they made silicone pads with same grain pattern I would be on board with that.
