Side Molding Removal Issues
The drivers side came off fine, but when I went to the passenger side, clear coat starting coming off with the molding on the door! It looks as though someone had put an extra layer of clear coat on this side and not removed the molding. I noticed the clear coat was attached to the top of the molding once I had already removed about 1/4 of it. With all of the other pieces already removed I went ahead and kept working.
After I had completely removed it, I stood back and nearly cried as there is a line of ripped clear coat where the top of the side molding used to be... I can't find any other thread or evidence of anyone else having this issue. I'm fairly certain the car has never been repainted as it only has 40000 miles on it. Now the only thing I can think to do is get the whole door repainted. Is there any other fix to this?
Also, on both sides, there is a faint line where the side molding used to be. I've tried everything to removed the "shadow". Goo Gone, WD40, clay bar, and nothing works. When I run my finger along it I can feel a line. I feel like there shouldn't be any raised line here as the side moldings were just stuck on with glue.
Please help here, any advice is appreciated. I am devastated that this beautiful paint is messed up now...
This has turned into a nightmare. I think I'm just going to put the side molding back on and try my best to cover up the ripped clear coat. Does anyone know the best adhesive to use to put the trim back on?
